Edges EZ box. How much timing?
rearend trouble
Valve Adjustment Question II
Anyone know if the EZ box alters the timing 100% of the time, or does it adjust according to conditions? I understand you can control where the fuel gets dumped into the system via a 3 position jumper wire (low end/high end etc).
Anyone have any details on this beast?
Always ready to help!
2000 2500 Red Sport quad cab, 4x4, K&N, DDI's, straight piped, boost, pyro and fuel pressure gages, Hot Power Edge, mean looking set of 33. 5" tires, Snap On diamond tool box, Marine Corps window sticker, Semper Fi!
1972 340 Cuda'. Original tripple Black, 340 car w/air. Good clean car, super stock springs, Weld Prostars, shaker hood, strong 340 with a 727/4000 stahl, 4. 56... . Bombs away!
NRA Life Member. http://www.geocities.com/chadsheets
Chad, you need to contact tx ram. He had some this weekend and seemed real knowledgable about them.
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, anti spin 3. 54 axle, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
I have an 'EZ' and it is a very good improvement to my RAM. I think $ to HP, it ranks up there very high.
When I first installed the 'EZ' on my truck, it seemed like a very huge increase in power. However, now, after some 10K miles, I hardly notice any change.
I think this is a result of some kind of disease.
Anyway, I've heard the cure is something called a 'Hot PE' + DD 3's,'or something like that. #ad
Bob in Sacramento, Y2K Black 3500 ISB 4x4 4:10 LSD,Auto,QC,SLT Laramie, Slightly BOMBED :) LB, Polished Stull Billet Grill & Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges,Rancho 9000's set at '1',Diamond Plated Tool Box, OEM U. R. Bedliner + other stuff.
Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
