Hello all... I am looking at various tire size options for two Cummins powered pickups & am curious about what gear ratio works best.
I am guessing that the factory ratios are ideal..?
Here is what I have going on....
I have a '97 Ram 2500, 6bt/nv4500, 4x4 that came stock with the 3.55 gears. It currently has some 18" later model ram wheels on it essentially giving it a effective ratio of 3.21:1.
I would like to get back closer to the stock ratio but 245/75s look so small on anything... this pickup is also pretty far down the totem pole of available project cash that changing gears probably isn't going to happen.
I'm assuming that I'm giving up a lot of grunt with 321s...I have a nice set of 265/75/16s that I could swap onto some Dodge steel wheels. That would get me to an effective ratio of 3.42:1.
Is that exponentially better than 3.21:1 or should I get myself back to 355s or even higher?
Likewise I have a old Chevy c30 also wirh a p-pump 6bt/nv4500... it has factory 4.10 gears & stock size tires... I am boring & don't plan on lifting or lowering it. I've considered throwing a set of steel 19.5 wheels but 225/70/19.5s are nearly identical in diameter to a 235/85/16 so no real change.
I guess what I am looking for....is your personal experiences with what is the ideal gear ratio for a 12 valve/nv4500?
Both of these vehicles are generally just driven around with no huge loads behind them. Both also will be called on to tow heavy trailers on occasion & need to be ready for such a task.
I guess that I like MPGs but don't drive either enough to make a decision strictly based on that.
A combo of MPG & towing power in the ideal range is what I'm after...probably leaning towards the power.
I don't want to preach the old mechanical Cummins gospel & not be able to get the job done when I need to move something.
Thanks in advance.
Thanks in advance.
