Egr???
Diesel fuel lubrication
recall on 2007.5, 2008 diesel
Ok, after getting rid of the DPF I decided to go ahead and make the plung to get rid of the EGR. I decided to use the blockoff plates for the EGR and block off the tube on the passangers side. I got started then got called out on a job, before I could get the Butterfly valve removed from below the EGR. I was concerned that this might not work, but whent ahead and tried it. I drove the truck 500+ miles (with the EGR gone/ unplugged and the tube blocked, just still had the butterfly) over the weekend with no limp mode. Now I do have this really annoying ding that reminds me that I need to see the dealer for service. "imidiate service" My question is this.
1) Do i need to go ahead and remove the butterfly valve?
2) How long before it goes into limp?
3) I removed it on my buddies CC and we broke both screws in the plate, anyone else have this problem? I would like to be able to put this all back together for when I take it into the shop, any suggestions would be great.
My opinion... .
#1 - If you don't notice a performance difference, then there may be no need. 500 miles should be plenty of time to see if there are any issues with airflow, but w/ no valve there is never the opportunity for your fresh air to get obstructed
#2 - Not sure it will, if it has not yet... ... but not sure on this
#3 - I think once those screws are out, they are out for good. They are in pretty darn tight, I broke off a bit unscrewing them. I am not aware of an easy way to remove/install them.
Are you planning on re-installing the DPF before you take it back in? Or just concerned about the engine parts?
The screws are peened on the back side. take a file or small grinder and file down to the shaft and they will come right out. Also they can be reinstalled.
Harlan:-laf
Just to let you know the EGR valve is not a butterfly valve and it is spring loaded closed. I don't know if there is ever enough exhaust pressure to open the valve.
#1 yes I think you should remove it, it can help prevent issues later. If it ever closes on you, you could have serious issues fast.
#2 I don't know, I use Edge Juice with Attitude, no dinging, no issues, tons of power
#3 if you first spray the screws a few times with a really good penetrating oil and then slowly work them back and forth, gaining a quarter turn each time, the last thread that is peened will separate and you can save the screws should you ever need to re-install. That's what I did with mine. There's cheap / easy ways to do stuff, but so far on this truck I have been finding that the more money I put into it the more I like it. :D
What would be cool is to hook up nitrous to the egr and use it as a controller or make a crack pipe out of it?? Wheres my lighter???
