First time first gen. owner. Long time gear head. I purchased the truck to pull my trail rig. Engine seems to be in good shape. I assumed it was all stock when I bought it other than the fuel pin being turned already. I have slowly made needed repairs to he truck and just now decided to turn it up a bit. Mods are 90 degree turn of the fuel pin, one turn of the star wheel, smoke screw is down 1. 25 turns, and full fuel is right at one turn in. Unloaded 4th and 5th gear hammer down I am seeing about 20 psi of boost and I can make the egts hit 1200 if I want. Normal cruising at 60 mph 5th gear egts hang at about 800-900. 4th gear pulling hard long grades 6000 lbs. behind the truck the egts will hang right at 1100-1200 boost at about 10-15 psi. The truck will maintain 55. I usually try to keep em at 1100. I currently have a stock h1c with 21cm ex. housing. I would like to get some more air in the engine and try to drop the egts a tad without building crazy boost numbers. Question is an 18 cm housing swap worth it or should I go with a 16? I would like to keep the boost down to about 25 psi. Also am I correct to assume that more air will drop the egts? One more question. I see all kinds of post about acceptable egt numbers. Some say 1100 all day long never more than 1300 for a second or 2. Some say 1300 all day and peak at 1500 for a second. Sorry for the long post and thanks in advance for replies.
