EGT gauge going crazy......
3k
Sneakers!
i've got an autometer pro comp ultralite. wed nite it started going crazy. the needle was bouncing uncontrollably under acceleration..... would calm down when i let off the go fast pedal... .
only thing dufferent is that i put on a COMP that actually WORKS.
anybody got any ideas? is it the thermocouple? or just bad wiring?
oh... have had the gauge for over a year... ... . TIA gang
I can tell you exactly what the problem is. I had several EGT gauges that did the same thing... and autometer replaced them free of charge.
On the older style gauges there was a little black box in which all of the wires connect to. Well. . to tell you the truth that box is bad.
Autometer finally went to a better style gauge in which the probe and power hook directly to the back of the gauge. Call them up. . they should help you out.
Kev
Yep! I had a brand new out of the box Autometer do the same thing. Sent it back and they replaced it. Box was bad. Good to hear they have changed to a better type. When this one takes a dump I'll know what to do. :)
I had the same problem towing a rental
28' travel trailer to Kerrville last year. The
EGT gauge would basically quit when I
kept the EGT's up towing on a long hill
with my Edge 3 light box on level 1. It
has not done it since then. I forgot all
about it since I don't tow that much
weight all the time.
Made me :mad: at the time, since it
quit working when I REALLY NEEDED IT!
