egt gauges & complete set-up
transmission Tc Lock-up And Temp Question
GFS 392 Questions
running edge-ez, looking for complete setup on gauges- can somebody please give me the info that i need, so i dont have any fraudulent warranty claims. truck is a 05, ho, auto ;)
As was mentioned on your other thread..... Guages do not cause warranty problems, the Edge WILL. I have run gauges on stock trucks and never had any problems with warranty issues. If you install a power adder (Edge) and the dealer finds it, you could very well have your warranty voided.
That said, you need three gauges, EGT's, Boost, and a Trans Temp gauge. I like the pillar mounts. I am just about to install a Westach Boost/EGT combo gauge using a pillar mount with the grab handle. It will be the second truck I have used the gauge on. This time though the pyro probe will be pre-turbo, and the gauge is a high output version to read higher boost. I am already at 75k miles so I am acepting the possibility of a voided engine warranty when I install a power adder.
You could do the single gauge mount with grab handle and do a dual steering column mount. lots of options. Genos Garage has a good selection of gauges and mounts. Check them out.
