EGT placement
90 VS 94 Ram door mirror question. Anyone have an interchange book?
amsoil bypass
I have read on several post before on placement for the EGT probe for pre-turbo but cant remember what the best placement is? Left or Right on exhaust manafold above turbo. Any suggestions? THANKS!
T4L,
Try this URL: http://www.tstproducts.com/images/gauges/exhaust.gif
This is a line drawing of probe placement. I used this drawing last Sunday when I installed my EGT gauge.
Good luck. It's not as bad as I thought it would be. I did drill the first hole in the air horn for the boost gauge figuring that if I screwed it up, it would not cost as much or be as hard to replace.
Make sure you vacuum and use a magnet to get all the metal shavings out after you drill & tap.
I almost forgot... If you use a 1/8 NPT like I did, make sure you drill a 5/16 hole. The drawing says 7/16. The larger hole is for a 1/4 NPT.
THANKS
THANKS fellas for the replys I can say THAT I DID IT WITHOUT SCREWING UP!!!!!! WOOOOOHOOOOOO. I drilled it before
I seen the drawing! I managed to get it perfectly located like it said!! Thats not my luck normally! THANKS A MILLION!
