EGT probe install question
Need some plate ideas!
Keep stock injectors for CO smog?
Dave
When I did mine I did it just like the TST instuctions said and it worked fine, I drilled mine through then swept it out for a long time with a magnet then coated the tap and repeated the last, worked out fine.
Jim
EGT probes
ditto. used old fashioned bearing grease on the drill bit and the tap. no problem. i put probes both pre and post turbo. when i got done drilling and tapping, used a small mechanic's magnet to sweep the bottomn of the manifold and the elbow. i didn't have the truck running.
