RUNNING 40-16 AND HT3B -26 AND CANT RUN MY TST COMP VERSION OVER 4-2 FOR A LONG PULL OR WILL BURY THE PYROMETER PAST 1600 AT 55LBS OF BOOST. STILL HAZING PRETTY GOOD SMOKE EVEN AT 50 PLUS BOOST, ADJUSTED VALVES, CHECKED BOOST LEAKS, CHECKED INTERCOOLER, REPLACED 450 DOLLAR RAIL RELIEF VALVE, AND ONLY DROPPED 50 DEG AT LOW IDLE ALL FILTERS ARE NEW OR CLEAN 5000 FT ELEVATION TRUCK IS AN 03 6SPD 4X4 PIERS TWINS, PUSHER PUMP,TST TWINS VERSION, 5 INCH EX WITH NO MUFFLER ATS 3 PIECE MANIFOLD TRUCK IDLES AROUND 230 DEG, CAN HIT 1150 ON 0-0, STILL MAKES 33PSI AT WOT AT 95 MPH ON 0-0
