OK, to start, the truck in my signature currently has 127k on it... I drive it no differently today as I did when I first got it. I have towed some, but those are mostly empty highway miles.
I only recently decided to buy a monitor, mainly for the rail pressure, but got boost and EGTs thrown in as a bonus. I hooked the EGT probe up this past weekend and under a WOT "hill" and unloaded, I can easily hit over 1300*F... which makes me wonder two things: how hot would it get towing on a long pull and is the guage reading correctly?? And the 1300*F mark was hit even with the monitor defueling at 1250*F (which was only a burst to 80mph before it shut me off). I bumped it up to 1350*F, but haven't been able to do a run since (raining)...
Then I got thinking, its a stock truck short the open exhaust and swiss-cheesed airbox. I did a search on EGTs and the 1500*F number came up as did the statement that a stock truck can't fuel to the point it causes EGT-related failure. Is there any worry about EGTs on a stock truck? Should the computer back things down "automatically"?? I can't believe guys are towing some of the things I've seen without guages, worry, or failures.
I actually got this because I'm doing a potential tow scenario from PA to UT in September... going to have around 10k on the wagon, plus whatever in the truck. I would really hate to be relying on this guage's readings (assuming they are wrong) and not pulling to the full potential, if there stock programming backs things down automatically.
The "manual" indicates I should complete a "max" WOT hard pull (under stock programming) to determine my "max" EGT... I would then add 150*F to that number and set the truck to defuel at that point. Does that seem correct? Seems like I would want the max reading to also be the defuel point?
Thoughts?? Should I be concerned?
steved
steved
