Egt"s What's (normal)??
Traded 99 5 spd for 02 6 spd
Adding DD II's
like to compare temps of equal trucks 5-speed @75mph flat no wind 900* 8lb boost pre-turb. shouldnt it be more like 600*? i can get 1300+ wot(havnt gon past). all#'s empty stock. with va box cools it 100*.
8PSI would almost tell me you were not on flat ground or into a head wind a little.
@75MPH you should be around 4-6PSI and 625F-675F range
@70MPH 3PSI and 575F-600F
are you sure you were on good flat ground? try turning around and comparing the two directions.
that is what I run anyway :D
