egt tap
My Lance doesn't fit in my 04.5!
New Truck Has Arrived.
my directions say to tap only enough threads so that the probe threads in 3. 5 turns by hand. is this what everybody is doing. mine has 1/4 npt (drill 7/16).
they also recommend never seize on threads. i was going to use Teflon tape to seal the threads. is this a bad idea?
There are good install instructionshere.
If you ever want to remove your thermocouple put neverseize on it. It's more for possibility of removal than sealing.
-Scott
Teflon starts going away somewhere around 600 F.
Wouldn't matter in this application, but it's worth knowing that as it goes away it turns into a poisonous gas (phosgene, I think).
