Ok, I've searched for EGT Probe, EGT Gauge, Gauge install and a bunch of others. The best I've found is the 3 gauge install from October last year BUT I only got about 25% of the pictures and didn't get the EGT probe position picture. Just a little frustrated...
Three requests...
Anybody have a picture of a drilled and tapped manifold? I want to go ahead of the turbo.
Do I need to pull the turbo so I don't send cast iron chips through it? I know about greasing the bit and using a magnet but it looks like the best place to tap is in the collector right above the turbo.
The probe came with a steel 1/4 pipe adapter and an 1/8 brass adapter (Isspro) . Brass melts at 1600 degrees so I should have much bigger problems if I melt that. Should I drill the bigger hole and go with the steel or drill the smaller hole and go with the brass?
TIA
Three requests...
TIA
