EGT temps...OK?
Dealer Thumbs up
Tank Heater
I finally towed our 8000 pound toy hauler with the SPA gauges installed and averaged 800 to 900 degrees while cruising on level ground with no noticable head winds. Is this OK? The unit is stock except for the gauges and a Dodge Jake Brake. Thanks in advance.
A OK
With DD11's I see 1200 when I hit the loud pedal at Low boost, on the 99. Then when boost builds it drops to about 1100 and holds.
your temps are about normal.
