I'm new to this forum... Hopefully you guys can give me some advice on where to locate the EGT Thermocouple on the exhaust manifold... I see that TST recommends installing the sending unit in the manifold between the turbo and the head, which makes sense... The part that concerns me is the possibility of shavings from drilling the hole falling into the turbo impeller. I know they're pretty close tolerances in there, and magnetize over time. It looks like a lot of you folks have done the installation... Did you pull off the turbo's to drill the holes? If so, how hard is it R&R the turbo? Thanks!
