A buddy who is not yet a member from around Calgary has a question that I said I would post. Here it goes...
My 92 is stock , with 243,000 km; I recently installed an egt ( Westach,post turbo) and am surprised at how low it reads under normal driving conditions. Most of the time it sits significantly below 600 deg F and the most I've seen is 800 degF. It's often
sitting on the zero mark and yet we all know that the exhaust would give you an aweful
burn if you touched the pipe after running the engine. Does my unit need recalibrating?
What is normal for an unmodified engine? The resistance of the probechecks out OK.
I'd be grateful if you'd post this query.
Regards Tony
Jason Hoffman
Lil' Mack - 89 D250LE 5 Spd 3. 54 LSD Reg Cab. K&N,"tweaked pump", BD Injectors, Banks Pyro/Boost, 3. 5" Exst tail section straight. E&M Custom seats. Bosch H4, PIAA 80W/80W HdLites. 100W Drv,55W Fogs.
237,500 miles (380,000 Kms) 7850 Hrs. Cummins Power Booster member.
The Original Turbo Diesel
Lil' Mack Pics/March 2001
[This message has been edited by Lil' Dog (edited 04-27-2001). ]
Regards Tony
Jason Hoffman
