EGT warning light……….interested?
who puts the oil filters on
Drag race 99 cummins VS 97 Powerstroke
Gentlemen of the TDRoundtable,
Who among us would be interested in an adjustable EGT warning light? The EGT gauge I have in my truck is the most important and the most monitored and as such I have the instrument in an A pillar mount. When running loaded (towing) EGT is fairly easy to keep track of, but when un loaded and on the smoke, things happen very fast and I find it harder to monitor the EGT. I have not worked out the details, but if there is enough response I will send off a letter to Autometer regarding the feasibility of such a retrofit to existing gauges and to the possibility of a stand-alone system. (Another hole to drill and tap in to the manifold?) Or using the existing T. C? I am sure this can be done as Autometer has a system they call Tri-Alert which can be hooked up to any of the 90 deg sweep electric gauges they offer and will trigger warning lights at any point chosen. The EGT gauge I have is a 270 deg sweep ultra-lite so I assume the Tri-alert will not work with my existing gauge. I would appreciate any comments, ideas or thoughts on this and if you are, in any way, interested please speak up. Pardon the long post.
Thanks
Andrew
I iknow the ISSPRO digital I used to have had an output for a warning device. It was adjustable too. I always thought a buzzer would be cool.
Chris
2001. 5 2500 LWB Quadcab 4x4 Auto 3. 54 Scotty Air
Sounds like a cool idea. A tri alert would mosy likley work with the EGT gauge but as much as i hate to drill another hole in my exhaust manifold, its the best way to go for installing an alarm. This way if the EGT signal box were to fail or a wire broke loose somewhere, you have a complete independent system for the alarm. This would most likley be important on an ISB with a lot of fueling mods where EGT's can get to a dangerous level very often. Then again, if your truck is mostly stock and you rareley if ever tow like mine, you would never have EGT's at a dangerous level anyhow, so a redundant warning system using a seperate Thermocouple is overkill. So i would go for one using the exsisting EGT setup on my truck.
I don't think using a separate probe and wiring. You would never know if that probe/wiring went bad. If you use the same probe, you could tell that something was wrong if the gauge quit working.
1999 2500 ST LB 4X4 Metallic Red, 5-speed, 3. 54 gears, LSD, camper and tow package
Westach Boost/EGT (pre and post turbo) mounted on A pillar.
I have one already, the SPA digitals have a programmable light built into the guage, one for boost and one for EGT. They also have 2 more programmable outputs that can be used for other things too.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S SPA Boost/EGT Rancho 9000's Everything but leather NRA Member Great Lakes TDR Member
