I have 1200 miles on my new pistons, replaced because of a bad genuine 275 injector. My prior setup had the EGT thermocouple in the exhaust about 3" from the flange. Temps then rarely saw 900. New setup is thermocouple in the turbo mounting flange.
Just back from a test run prior to going on vacation. I pulled my 5er (10,000 lbs)17 miles up a 6-6. 5 percent grade starting at about 4000 ft. and going up to 6500 ft. Traffic was a little heavy but I was able to let it drag down to 35 then went WOT the last 2 miles.
At the top (6. 5%), speed was 61 mph, high gear, no lockup, engine turning about 2650, turbo 28. 5 psi, EGT was only 1140
So my question is. Am I just real lucky or could I have screwed up the putting it in. It looks good, doesn't touch the manifold, is positioned exactly as the directions posted at Genos.
Oh yeah, the new pistons are ceramic coated. That is the only real change. .
