Details here: TDR Privileges
No, you can keep the Jacobs with most of the 4" systems, they just neck it down a little at the Jake. Works great, mine never gets over 1000 even with 10K strapped on the back. Do it, you will love it.
The MBRP systems we sell will bolt right up to the brake housing casting and work fine. There is one brand of brake out there that requires you to get their down pipe to make it work, but all the others just bolt right on. Call us if you have any questions we'll be glad to help.
Fill out your signature so we can see what you are driving. Makes it easier to give accurate advice...
I recently installed a 4" Magnaflow exhaust (thanks Rip) and a bhaf and noticed a good drop in peak egt's while pulling steep grades. I went with the Magnaflow because of its near stock sound levels.
For a driving tip, watch your rpm's on the grades. If the egt's are getting hot, down shift. I usually downshift to 5th (above 2000 rpm) to keep things in order on the really long steep 6% grades. Before the upgrades I was downshifting for most grades. ]
