I have yet to see the EGT gauge read anything less than 275 except when the truck is just started. Driving the cold truck 1/4 mile to a stop sign and subsequent idle it reads 275. Should I be seeing temperatures less than 275? Based on the forum searches I've done it would seem that many are seeing temperatures closer to 250. Maybe the calibration in the gauge? I did read about the gauge being calibrated at, I think, 72 degrees and any difference from that results in slight changes in the indicated temperature.
After a moderate drive and one minute idle the EGT's are 300 which I'm going to use as my target temperature for shutdowns but I'm curious if I should really see any readings less than 275.
