EGTs, Engine Temp, and Coking
600 Injector/Knock Question
Do you "wait to start" in the summer?
My pyro gets down to 300* quickly, even after extended high speed runs or 50 mile pulls. I have my PwrMaxCR set on 4/4 for general driving and 3/3 for towing. Stock exhaust.
I can usually get to 300* within 1 minute no matter how hot the day or long the trip. The Owner's Manual has a cool down schedule expressed in minutes.
What is the correlation between the two - engine temp and EGTs?
When the pyro reads 280* and the temp guage is slightly below center, it would seem logical to shut it off. If there is a hidden relationship between the two I would like to know.
The real question is, is it safe to shut down when the Pyro reads 300* irrespective of the amount of time it takes to get to that point. Are EGTs accurate for determining shut down time?
This question went unanswered on another board in a similar thread. The point was made during that thread that turbo bearing seldom "coke" regardless of the treatment, but thats another discussion.
I run two pyros one pre turbo for the tst & one pyro post just in case. After a hard run the preturbo pyro will hit 300 deg on cooldown - the post turbo pyro takes up to an extra two minutes to hit 300 deg. I use the post for shutdown temps after a hard run. Normal driving I just shut the truck off, no cool down.
This is my 5 th cummins since 95 - no turbo problems yet -
having said that, probably blow my turbo tonight:)
It is a good rule to shut down below 300* post-turbo, regardless of engine coolant temp. Having said that, if I come to a stop after a long highway drive I always let it run for a little bit before shutdown even if the temp is already below 300. In fact, most of the time I wait until below 250, just to be sure. Plus, as JHardwick pointed out to me once, it's good to circulate some cool oil around the engine before shutdown.
At first, with my original '91 truck, I too was concerned about turbo cool-down - but as I got settled in to the truck, I eventually took a couple of minutes for cool down after a hard pull with our RV to shut down, but other than that, just maybe 30 seconds or so, and shut her off... Truck had nearly 120,000 miles when I got the '02 - never the slightest problem with the turbo - or anything else for that matter - musta been the STP and my Frantz bypass filter... (inside joke... ) :D :D
