We're all pretty much aware of what EGT's do in a diesel engine. A diesel (in general) can idle all day long and maintain low EGT's. But what happens in a gasoline (non-turbo, non-supercharged) engine during extended idling? I've never really thought too much about EGT's at idle in any engine until I got the Dodge.
The local Dodge dealer shop once told me idling their V10 for long periods will eventually burn up the catalytic converter. We got into a discussion about high idlers for diesels and eventually started talking about gas engines.
Do gassers have higher egt's at idle than while under load? I know you can buy high idlers for gassers as well as diesels.
If they are higher at idle... would a high idler reduce the egt's since you will not be at idle? If true... I would suspect the throttle plates in a gasser would reduce airflow thus causing the higher egt's at idle.
