Egt's Help
Cold starting tips
New to Diesels and the TDR
Help!!!!!!! This Is My First Diesel Truck. Should I Read The Egt Temp On The Pre Side Of The Turbo Or Post? The Truck Is Stock. I Will Be Looking For More Hp Soon. Please Help The First Timer Out And New Member.
New Owner Of 2005 Quad Cab 2wd Silver
DavidC said:
Welcome to the TDR.
Pre side. If post add about 300 degrees is the general consensus.
Dave
The 300 difference is only on a STOCK truck! Wth my setup pre I can hit 1400+ easily on a WOT run empty. With the same probe post I only see ~800 on the same test!!!!! If you want to be SURE put it pre and 1300F is the limit for safety on our trucks.
John
