Engine/Transmission (1994 - 1998) EGT's...how low did they go aftmkt ex??
2nd Gen Non-Engine/Transmission Lindstadt Track Bar?
2nd Gen Non-Engine/Transmission Lower a 4x4 ?
What kind of results have you seen from your aftermarket ex system as far as egt's going down on a pull?
I have heard everything from "cut out the muffler" works well to a 5" aftmkt system... .
I dont care about noise. But would like to make things cool down a bit.
with the mods, I am 285HP/rear tires
A 4" banks system and ATS manifold made little if any difference in my EGTs when emty. Turbo spools quicker and it may help with EGTs with a load but I don't know.
Sounds good and should last anyway.
Just put a 5" with Donaldson 51" muffler and a smaller resonator on a couple of weeks ago. Made a bigger diff. than I thought it would empty or pulling. I think it made a bigger change in my truck than most because my old exhaust system was a complete hack job with unknown muffler, leaks and a bunch of tubing size changes. I changed it out more because I was embarrassed by it than anything else.
I'd say my egts dropped a good 150* empty on the freeway and have to work hard to get to 1200* pulling where before I could hit 1300 and climbing easily. Time for more fuel!
Can't say on pulling yet with the 5". Empty and cruising down the road it's maybe 50* cooler. Peak temp has dropped maybe 150*. Haven't had a chance to really see what it'll do yet with all the road construction around here. :rolleyes: The turbo is more responsive and spools up quicker. The throttle response feels quicker. With exception to what's in my sig. , I'm bone stock.
