This is kind of a confusing question but here goes. At a given power output will there be any difference in EGTs between DD2s and DD3s? Say you're towing something down the road, at partial throttle using 200hp to do it. Will the EGTs from DD3s be higher than the DD2s doing the same thing?
I've got an 02 ETH with DD2s, an EZ, HX40-16 and may want to do some DD3s but I tow with it. I know max, full throttle EGTs will be higher. I hardly ever use the max output but don't want any higher temps when cruising.
I may be off on this but I had imagined the DD3s would run hotter than the DD2s maybe because the spray pattern was not as fine or different. Thanks guys.
