Well I have my twins in and my egt's are still high. With the fuel that I have, I only put down 298 with my stock 35 and at 1800+*. That seems a bit high to me. Now that I have my twins on, egt's are still up around 1500-1600 on a hill, of course I don't keep them there for anything but a second or two. I have hit 52 psi so far. Cruising egt's with a my stock trailer are 900-1000* at 70 mph and about 18psi. I guess I was looking for better results than this on a truck that is maybe putting down 350hp. Maybe my wastegate is all screwed up. I worked pretty hard on modding the stock 12 cm housing by enlarging the wg to 1" instead of 3/4" that it was before. Lathed a new flapper and then milled out the center divider to gate all 6 cylinders too. Spool up is not all that great. What do I do? How do I set my 35 gate correctly? Should I put back on my stock 12 housing? Look into an external wastegate? If I did this can a somehow weld it onto the 35 exhaust housing or do I have to make a new piece between the ex. manifold and 35 exhaust housing? I will say that the pickup is a lot faster, but thats not really was I was going for. Are my numbers way off or do they seem about right? Bottom turbo is a BHT3B/26 with out a center divider.
Thanks and sorry for the long question.
Jamie
Jamie
