Wanted to see if what I am seeing sounds right.
On my '95 12v AT I have the timing set to 14 deg and a cust plate that is close to a #5 in looks and it is slid all the way forward. With just this done the truck would hit 1300deg around 80MPH from a stop.
Today I was rechecking my timing and put my 191 DV in. On my 1st test drive the truck pulled much harder but the EGT's pegged 1500deg by 50mph. If I roll on it just cruising the EGT's almost move as fast as the boost gauge. Before with my boost controller I was set at 35psi. I am now straight WG line no bleeder or controller and it is still reaching 40psi on the stock HX35.
I have a cheap 16cm waistgated 58mm HX40 and 370's to put on still, but I am thinking the EGT's will still be out of control.
I thought with the 160pump I would have a hard time getting enough fuel, but I guess I was wrong.
Do you guys think with the HX40 and 2-3deg more timing I might be able to keep the EGT's under 1500deg if I put the 370's in?
Mods
-cust 3. 5in DP right off the turbo no cast elbow
-4in straight through exhaust starting after DP with a diesel Magnaflow muff and a turndown right after the muff which is right before the rear axle
-Cust plate looks like a #5 plate slid all the way forward
-3 GSK with the shifts set at 2800 RPM
-191DV
-Built transmission with good converter
-Boost creeping to 40psi.
-stock hose to a 7in around and 8in long K&N filter with a prefilter over it.
Mods
-191DV
