EGT's
going to arbitration-- any tips
Drive clutter
Have you done anything to your truck powerwise? I ask because those temperatures seem a bit high. How much weight are you towing?
'99 2500 ISB QC SLT (No Leather!), 4x4, 5sp w/McLeod, 4:10, BD-II, PE, PE-EZ, 4"exh. , Pac-Brake, A-Pillar gauge pod w/boost and pyro, Line-X, V-1, lights, siren, lic. plt. frame says "Diesel Fumes Make Me Horny!", and much more goofy stuff.
i have the same problem even with the HX35 and a straight piped exhaust and open airbox. just running around empty i can hit 1000*f easily, if i really get into the pedal i can hit 1500*f just under acceleration with no-load, why so high??
Jeremy Kern
1999 2500HD 4x4 QC,SB, ISB, 5spd, 3. 54LSD, 33x12. 50 cooper STT's Denver off-road bumper with Ramsey RE12000, PIAA series 520, Rancho RS9000's, heavy ft. springs, JVD Torque Enhancer, DiPricol boost and pryo gauges, and a bunch of other little things! www.geocities.com/phrn30 for pics!
Well what are your boost levels at those EGT levels? Thats a key ingredient to the equation here. The reason it is high is because you have a "fueling" box, which will always raise EGT's considerably.
Ooops... Somehow my sig did not show up that had the specs on my truck.
I have a 2001 4x4 3/4 ton automatic. Banks Powerpack, DTT T/Q and VB. The turbo is a 9 cm.
Can I change to the 12cm turbo?
Yep. You can also try a free flowing air breather like a drop in K&N, or get a psychotty system to help drop it down a good 100-200 deg. That small housing on the turbo isnt doing you any favors in the cool dept. If you could get a boost module to raise the boost to around 35 that would also do you alot of good in the situation you are in Hope this helps.
Always ready to help!
2000 2500 Red Sport quad cab, 4x4, K&N, DDI's, straight piped, boost, pyro and fuel pressure gages, Hot Power Edge, mean looking set of 33. 5" tires, Snap On diamond tool box, Marine Corps window sticker, Semper Fi!
1972 340 Cuda'. Original tripple Black, 340 car w/air. Good clean car, super stock springs, Weld Prostars, shaker hood, strong 340 with a 727/4000 stahl, 4. 56... . Bombs away!
NRA Life Member. http://www.geocities.com/chadsheets
I have the K&N. Max boost is around 38lbs.
If I go to the 12cm housing will I lose any bottom end? What will be the performace differances.
2001, 2500 Black 4x4, Bank PowerPack, DTT T/Q and VB, K&N. Max Boost about 38lbs Pulling a 9000 Weekend Warrior full of dirt toys for the whole family.
Hello everyone,
I am a new mwmber but long time lurker... #ad
I am not sure what range of EGT's everyone else is gettting into but I feel that mine is a bit high when towing. Usual freeway driving I average 800 unless I really put my foot into it. Then I can hit 1300 like nothing. Is this normal. When towing I have to keep an active eye on the pyrometer of else I will exceed 1300.
I have the small turbo (9cm) Will change the turbo help?
Thanks
Jonz
