elect. brake controllers
2100 Miles in 48 hours.
hauling for extra dough
What kind of brake controllers are all you guys using? The last one that I installed in an Econoline was tapped into the hydraulic line of the master cyl. The new ones out seem to be all electrical. What is the best and who makes it? I'm buying a new 28ft. Aljo bumper pull that brakes on all fours and weighs 5600lbs empty Thanks, Chris
I am using Tekonsha Voyager 9030 for 2 or 4 brake system. I pull a 31' 5th wheel. Works fine. I don't think you can use the hydraulic actuated system on the trucks with ABS. bg
White 99 3500, QC, 3:55, auto. most options except leather, Line-X bed liner, fiberglass running boards Rancho 9000s, bug shield and window vents, black vented 5th wheel tailgate, 110 gal. aux. fuel tank.
I was told they out-lawed the good kind [hydraulic]
I got an electric [jap name brand], mine only has
one setting of pressure. You can adjust how hard it applies
the brake, but it doesn't apply more when you apply more foot
pressure.
I don't like these new kinds.
The adjustment seems to be very sensitive too. I think it is a Tekonsha too.
97 3500 SLT REDext cab duelly p/u 5sp 3:54 2wd 245/75R16
3" straight exhaust stock torque plate slid full foward star wheel tweeked
105,000 miles still with plenty of ZOOM... ZOOM... ZOOM
RON Z
I use Draw-Tite's digital controller. It has adjustable settings for delay (how fast the brakes come on) and intensity (how hard the brakes come on). I am pretty happy with it, except when in stop-and-go traffic (construction zones). Even light pressure on the brake pedal brings on the trailer brakes fully (until pedal is released), as if in a normal stopping condition. This can be too much when you're just trying to control you idle speed. I believe some of the others (Tekonsha?) have a sensor which applies the trailer brakes proportionaly to your truck brakes.
One thing to remember: follow the labels on the wiring harnesses, not the colors. The blue wire on the controller does not necessarily attach to the blue wire on the truck, etc.
You might take a look at this site: http://www.fortunecity.com/marina/finisterre/1228/jorjan/id19.htm
Zzman, this does apply braking power according to the brake pedal activation. It has several advantages that I wanted:
1. Activates with the brake pedal
2. No build up of trailer brake application for those long periods of slight braking.
3. Not affected by inertia or gravity.
It isn't the most economical unit but I love the way it works.
Drop me line if any of you have questions.
<font color=#990000>~<font color=#990000> '99 2500 SLT <font color=#990000> ~ QC ~ 4X4 ~ LB ~ Auto ~ 4:10 LSD ~
<font color=#000000>*<font color=#990000> BD E-brake<font color=#000000> *<font color=#990000> BD Autolock<font color=#00000> *<font color=#990000> Gear Vendor OD<font color=#000000> *<font color=#990000> Jordan Research 2020 T-brake <font color=#000000> *<font color=#990000> Bullhide spray-in Line <font color=#000000>*
<font color=#000000>*<font color=#990000> 2k Komfort 5'er - 9,700 lbs <font color=#000000> *
<font size=-2>... Lookin' for the 'RE' to go in front of my 'TIRED' so's I got more time to Play!... <font size=-1>
[This message has been edited by Rattlin (edited 02-03-2001). ]
Chris, I also have a jap made brand. got it at autozone. $60. 00. . Seems to work fine. It has both hard and soft setting. The last one I had in my last truck looked identical to this new one but cost 20 bucks more. If you have an auto zone out there you might take a look. Dodge also has a plug under the dash that you can use their pig-tail to plug into. of course it depends on what year model dodge you have. older trucks I don't think have that option.
2001. 5 2500 4X4, QC, Auto, 3. 54 LSD, SLT, SWB, Trailer, Camper & Snow plow Packages, White, 35k# Cody Hitch, 20' Gooseneck Lowboy flat-bed Trailer.
Hey Rattlin, Thanks for the tip on the 2020 brake controller. I talked to the owner of the company and he explained the full function of the controller. I ordered one, should be delivered tommorow. $139. 95... Pricey, but I'M WORTH IT!!!! #ad
Chris
Tom C, the bandits at my local Dodge dealer wanted $60. 00 bucks for that little pig tail plug-in. I wired it with my own connectors a year and a half ago. . works fine. . shop rate $. 00 #ad
Ron
96 4x2 2500 Auto,3. 54,K&N filter,Cobra radio 93 TT Terry, '84 VW Rabbit diesel,
Chris,
That's great! I've put about 13K miles on mine with no problems. As you mentioned, I didn't like the trialer brake build up when in slow traffic that happens with some types of controllers. With inertia types, I'm not sure how they respond to slow braking conditions.
Here's how one of the guy's (Sandman)from here mounted his unit. http://albums.photopoint.com/j/AlbumIndex?u=589847&a=4880909
Another installation was under the steering column. Longer screws, going through the stadard mounting holes, were used to mount the unit to the underside. I don't have a link to that site.
If I can help, let me know.
DrawTite Activator II
It has digital readout and works really well when pulling 28' Dutchman.
2001. 5 2500,QC,4x4,ETH/DEE,Dk. Garnet Red,Agate,E-Brake w/shifter switch, every option but leather. 700 miles as of 2/7/00
