I got a 98 that has lost all the gages and the alt. has stopped charging. Everything else works as it should including all the warning lights that come on when you turn on the key. The mileage indicator dose flash off and on and the gages will move a little when you first turn the switch on. I am thinking there is something common between the two or do I have two problems? Any kind of help would be nice. I thank it will be a loose ground wire some where but where?
