Here's a good one: the turn signals in my '90 D250 work fine, but the hazard flasher circuit is inop (I've checked the flasher). BUT, when I turn on the turn signal (left or right) and THEN try the flasher, it works- provide the ignition key is in the "run" or "accessory" positio). When the ignition is off the hazard flashers quit working. How the heck does an ignition switched power source get to the "always hot" flasher circuit? Any ideas where I should start looking first?
