2nd Gen Non-Engine/Transmission Electric fan for A/C condesor coil
Engine/Transmission (1998.5 - 2002) Truck has the Studders
Engine/Transmission (1998.5 - 2002) Injectors And Nozzles
I wanted to install an electric fan in front of my A/C condensor coil before summer, but there is just not a lot of room between the coil and the back side of the bumber. Has anyone added one, and did you notice any benefit? From what I can tell, the largest fan Jegs/Summit has that will fit in there moves 800 cfm. I was going to tie it in to the A/C clutch, ie- clutch is on/fan is on.
I did this exact thing last summer. I bought a 10" electric fan off ebay and mounted to the front of the condenser and made it push air toward the engine. Works great and keeps me cool at the long stoplights. I did have to cut some of the platic off the top pad for clearance, but you can't see it with the hood shut. I also wired to fan clutch.
