whew! good lord... ... ... like the instructions say, you'll need every bit of four hours to complete. it is an awsome piece! i love it. i only have one complaint; the wiring has a little bit to be desired. its ok, but could be a little more neat. everything went well. i took shroud, fan, and brackets off; i thought, i was going to be done in 2 hours, max... ... ... . then the wiring. the temp. sensor wires are very light guage and they give you just enough to hook to control panel from the inlet of radiator. good gravy, dont mess up that splice or your going to have a tough time reaching the control module (panel). second, the wire from the fuse box... ..... this piece should be soldered into place through the back of the fuse box not attached by a cheesy adapter. i will tighten it up tomorrow, will solder wire into fuse box and should be happy with it. the cooling is great, i noticed a 10 degree drop in engine temp. i also noticed a little less noise and it feels a little less shaky (cummins style). maybe its because i've talked myself into this as being the grand pooh bah! i will be able to tell for sure by the end of the weekend, going to the cape for a few days. hopefully it will be hot, so i can put it to the test!
