Our previous V-10 3500 would run hot (230 degF) in stop-and-go traffic towing our 13,500 lb 5th wheel in hot (100 degF) Texas summer weather. Brilliant guy that I am
, I decided to replace the factory fan with a dual Flex-a-Lite electric puller fan setup, complete with shroud, etc. This was the biggest mother Flex-a-Lite sold for the 3500 V-10. I figured this would cure all my towing ills.
WRONG!!!!
Once I started thinking about it, the Flex-a-Lite fans drew 50 amps @ 12VDC - 600 watts. Well, 746 watts = 1 BHP. Now, if the factory fan draws 12-20 BHP (depends whose numbers you use), even if it's only half as efficient as the electric setup, which one is going to move more air?? Sometimes even engineers have brain fade.....
Off came the electric fans!!
The final cure for the 230 degF temps on the V-10 was as follows:
1. The largest B&M SuperCooler transmission cooler I could get plumbed in upstream of the factory radiator tank and oil-to-air coolers. This got rid of much of the heat load from the auto transmission torque converter (tremendous heat buildup during stop-and-go towing) before the heat was dumped into the coolant in the radiator tank cooler.
2. Changed thermal fan clutch from 224 degF (stock) to 205 degF (aftermarket).
After these changes, you could work the crap out of the V-10 and the temp gauge would never go over 205 degF (factory thermostat and mid-scale mark on temp gauge is 200 degF).
An expensive lesson learned about electric fans and towing... hope the money I spent for my education helps someone else.
Rusty
