Electric Fuel Pump power location
Control Timer Module
Rip Rook exhaust??
I am currently installing an extra Fuel tank in my 04 Ram. I am planning on using an electric fuel pump, and control valve with a toggle switch for control. Can anyone tell me if there is a easy way to get power at the fuse box, that will be available only in the run position of the ignition or when the truck is running, I would like to have this circuit fused for protection, any suggestions would be appreciated. I have read that a blue wire can be found under the dash, but would like to bring in a separate wire from the fuse box as I don't want to overload the factory wiring.
Thanks
Amen to what Dave says. If you really can't afford it, though, there are a number of "spare" fuses in the factory box that I *assume* are available for power. If you can't locate them let me know and I'll try to post a pic...
-Ryan
