I'll keep this as brief as possible. I've been chasing electrical issues for a long time now, mostly for auto transmission shifting (very modified trans). I've replaced all the trans electronics multiple times and also the TPS. Sometimes it's fine but I still often have 2nd and 3rd gear starts and (yes, this next part is true), it won't upshift into 4th if the A/C is on. No issues with lockup.
This past summer I replaced the starter and alternator (both were bad), and got new batteries the year before (they test good). It's been sluggish to start anyway, and someone was able to pull off my main positive battery connector cable without loosening the clamp the other day when the truck wouldn't turn over in town, and wouldn't respond to jumping from another Cummins.
Yes, I've cleaned all battery connections many times, lightly greased them, and tightened them as far as they can be tightened. So I pulled that connector apart, cut a sliver off the inside of the clamp with a hack saw, and re-tightened. The truck has been turning over very quickly for the first time in years. And before anyone suggests it, I'll throttle the next person who tells me to check my grounds!!!!!! They are PERFECT as are all my battery cables.
I went through all my wiring around the charging system, even isolating that one large wire from the fuse box to the alternator. Everything I can see is pristine.
So. I've been hearing an electrical feedback in my radio off and on, and sometimes while driving my radio will blip off very briefly. My ignition has been difficult to turn from time to time, like it's turning in frozen molasses, not as if the key or something is catching (has happened when hot out as well as winter). I even had trouble getting the truck back into park once and couldn't turn the key off (not a linkage/transmission issue!) with truck not running. Oh, and several times my shift indicator (PRNDL) does not properly reflect gear position, then fixes itself.
Lately while I've been driving the truck feels sputtery, like it's low fuel when it's not. I'll run my electric fuel pump which is plumbed directly into the injection pump, and it doesn't help. It is freezing here but all the pumps run winterized fuel (as far as I know). Today after a couple hours of driving, multiple re-starts and a bunch of highway time, it started sputtering and no matter the amount of throttle it died; electric pump was on. Luckily it was on a back road home so I was safe. I tried re-starting and it turned over quickly but wouldn't catch. Then I checked the fuel shutoff solenoid and found it was not going up and engaging. So I pushed it up manually, turned on the electric pump, and after some cranking it sputtered to life very roughly. It smoothed out and drove home no problem and it shut off fine.
Some of these things could be unrelated, but I thought I'd list it all just in case.
Could this possibly be the ignition? The truck is 20 years old this month and it's never been replaced. I hate throwing more parts at it, but this is seriously getting old! I suppose it could be the shutoff solenoid itself, but if the ignition is not providing the proper voltage, couldn't that cause it to fail? Plus the other symptoms..?
I'd appreciate any advice, thanks.
