Symptoms for the last year.
Tough to start.
Low voltage after startup - somewhere in the 8V range.
Wait to Start light starts to flash somewhere around 30 minutes after startup... flashing slows... eventually it goes off and the truck goes right back to normal 14V operating voltage.
So far, I've:
Replaced the ground cable and negative to body ground (that solved a lazy/slow turn signal issue I've had for years). I wasn't getting a good ground between either the body or engine and negative terminal before.
Replaced both relays for the grid heater.
Unplugged every fuse and relay during the low voltage window... nothing fixes it.
The only other two things I can think of are the alternator/regulator or the ECM (if that's what it's called) on the inner fender well next to the battery.
The one thing that is odd is that the relays are not being told to send voltage to the grid heater even on a 35 degree morning.
Any thoughts would be greatly appreciated.
Mike O.
Tough to start.
So far, I've:
Mike O.
