Electrical plug replacement
Best way to remove chrome cover on wheels
convex mirror on replacement is not defrosting
... Can you buy just the plastic end for certain plugs... namely the 4 wire connector on the fuel tank module? If so, how do you seperate the stupid lil' buggers!?
Many connectors are available,I beleive I have seen that one. Your dealer has a website to look up connectors. The lock must be pushed out first then you can just lift the lock tab and slide the wire out.
Bob
The red tab broke off back when I did the vent kit mod,now today while I was rerouting the 3 small vents on top and wanted to peek inside the tank , the locking tab broke off. . barely even lifted it to unplug and... . SNAP :( So for the meantime I put some silicone around it to hold it in place for the time being. What I need is the outer shell, for lack of a better term.
The red tab slides sideways to allow you to squeeze the other release to disconnect it. Most times it comes as a pkg,insulator and short pigtails.
Bob
I think this is the connector you are talking about:
Mopar Package #
05013978AA
FUEL PUMP MODULE - LT GRAY 4 WAY
CAV CIRCUIT FUNCTION
1 Z211 18BK GROUND
2 K4 18BK/LB SENSOR GROUND 1
3 G8 18LB/BK FUEL LEVEL SENSOR SIGNAL
4 A64 16DG/WT FUSED B(+)
The part number is repair parts kit for connector.
Mopar Package #
05013978AA
1 Z211 18BK GROUND
Yep, that was it. Thanks artie! Had to order it in, arrived this morning, installed and one less thing to worry about for the time being! :rolleyes:
