When key switch is turned to the start position I am missing the following dash indicators: check engine light, gen light wait to start light,water in fuel light trans temp light. Once the truck is started there is no tach or speedometer the O/D will not engage the charging system is not working and the trans appears to be in limp mode. I have checked all fuses, relays, and wiring connectors also tested batteies and connections everything is VOM/OHM testing ok. Called dealer and they seem to know less than me. I have no way to access codes. Is there a relay or something else I am missing
