Problems were press brake pedal and radio display goes off, but radio display does not go off with headlight on. All marker lights, including front turn signals and cab marker lights would light up when brake pedal depressed. Rt turn signal works with headlight off, but not with headlight on. It
would also flash all maker lights as well.
Lt turn signal worked normally and would not flash marker lights. I started out by disconnecting the right side wiring and everything worked normally on the left. I then reconnected only
the rt. side marker lights and left rt. tail light disconnected. Everything worked
normally. I then thought I had a short
in the tail lamp assembly. I connected the rt. tail light again and problems returned. I then pulled out the bulb, tried it out and everything normal. I pulled the bulb from the left side and put it on the right. Everything normal. I put the bulb from the right side on the left and problems transferred to left. I replaced bulb and everything works normally. Never heard of a bulb causing that kind of problem before. Funny thing is the defective bulb flashes
like it is good and tail light would turn on like it is good. Anyone ever heard of a defective bulb causing that kind of problems?
Would be a great bulb to sell to a dishonest mechanic in install in customer's cars. They could make thousands. Just kidding, already smashed it and into the trash.
