Just a little while ago my lights started flickering. They are not at the point were they are going out but just flickering. This is not the normal grid heater draw either. There is not ryme or reason to it. I started looking at everything and noticed corrosion on the both of the battery terminal wireharnesses. It is all the way in the wires on these harenesses. Would this gause this problem? I checked the headlight switch and it looked ok. How do I test if it is my grid heaters or not. I put a new solenoid on it about 20000 ago. Could it be the altenator and is there a way to check that. If it is the voltage regulator do I have to replace the PCM and is there a way to check that as well. I love this truck but lately it has been non stop trouble. Although before I had about 30,000 trouble free miles.
Thanks in advance
Russ
Thanks in advance
Russ
