Electrical problems
Brake Pull
Colorado 1st gens; last test and tune night Oct. 5 th
My turn signals quit working the other day after a hood up a trailer with bad wireing. I blew a fuse, which I replaced. I replaced the turn signal relay also. The hazard light still work. Also, my ABS and Brake warning lights went on at the same time and are still on. Previously, I had a problem with the radio, blinkers not working, and the ABS and Brake lights coming on. However I just restarted the truck and if always fiixed the problem. Not having turn signals is driving me crazy !!!! I feel like such a jerk! Help!!
Lites ???
If you don't already have one get a test lite and check every single fuse in the holder with the key on, on both top pins of the fuse for power. You may find one more bad one. Also look under the dash and find the brake lite switch (mounted where the brake pedal can come into contact with it. Check it for looseness or out of position or adjustment. :)
Good luck R C
I got out my electrical tester and sure enough I had missed a blown fuse. I must have blown two and over-looked one of them. Lesson learned. Thanks guys.
