All, I am coming from a different forum trying to get some kind of help for this annoying problem
I am having some trouble with the electrical in my truck. I am a novice when it comes to electrical system so anything will help.
I have listed all codes that I am getting below. However I would like to focus on P0107 and P0073 for now as they are immediately present after I reset all codes. I know the MAP sensor is receiving 5v. Is the Inlet air sensor on the intake filter supposed to be receiving the same 5v? Is it in that 5v circuit? Because it is not receiving any voltage as far as I can tell. I cannot see any obvious wiring harness damage.
Should all sensors be receiving the 5v? Crank position/cam position/ AAPS/ MAP/TPS etc?
Battery terminals are very clean and connections are tight. Grounds to block and chassi seem to be clean and tight.
Anything helps. thanks so much.
P2121 – APPS 1 performance
P1652 – J1850 communication Bus – guage cluster dies
P0107 – MAPS
P0073 – AATS
P2127 – APPS
P2509 – ECM/PCM input signal intermittent
P0541 – Intake air heater control 1
P2149 - Injector group 2
Grounds from driver battery to body, chassi, and block as well as grounds from passenger battery to block and body are clean and tight. Batteries are at 12.7 and 12.8 volts will load test them today. terminals and posts are clean.
Does anyone have any information or can help me with a systematic approach to track down this problem? I rebuilt the whole motor and have brand new injectors in it and I can't take it anywhere. I'm desperate, anything helps.
2005 3500 5.9L 4wd, Stage 0.5 bbi injectors, stock 48RE
Thank you
P0107 – MAPS
P0073 – AATS
P2127 – APPS
Thank you
