When I start my truck,I turn on the key the wait to start and water in fuel lights pulse on and off. Under the hood I could hear the fuel pump relay clicking on and off, I replaced it and it does the same thing. After I start it the lights pulse and the tach stays at 0 for a minute then pulses for another minute. Ijust got back from Oregon. on the way back the cruise control started kicking out, I hit the set button and the tach would drop ,the wait to start would flash, and the transmission would shift out of overdrive. This problem is intermitent. I went to get the fault codes and nothing comes up, not even the 5 5 code. Does this sound like my controller is going out?
Thanks Mike
92W250,auto,3. 54,16cm2,JRE injectors,borgeson joint,3 1/2 dynomax race magnum ex. ,addco sway bars,seatco seat,peeling white & silver,K&N filter, Isspro boost&pyro
Thanks Mike
