I have a 92 and the charging system has gone crazy. Yesterday when leaving work the voltage meter went to 12 volts and the fuel, temperature and oil pressure were reading high.
Use the turn signals and the volt meter goes to 8 and the temperature cycles in time with the turn signal. The fuel and oil pressure gauges just peg out.
With the motor running and in my drive way I turned on the lights and the voltage went to 8 and the other three meters went to max (high).
I let it set for 30 minutes and started the motor again and the same sequence of events happened. I cleaned all the connections at the battery and alternater about two weeks ago prior to going on vacation and recleaned the battery terminals yesterday also. Battery is 2-3 years old and the negitive cable is new. I checked the battery with a hydrometer and all cells read good.
Started it up again and all was well. This afternoon was on my way across town and the volt meter went to 12 volts and the meters went high. The best thing was when I turned on the lights to see if they affected the gauges as before the speedometer went to zero and stayed there till I turned off the lights.
When charging now the alternator is erratic. Close to 14 volts sometimes and half way between 12 and 14 sometimes. The voltage will go down when ideling and go higher when the RPM's are up.
So has this kind of thing happened to anyone else with a first
generation. Any ideas: battery, alternator, fuseable link with high resistance,engine controller or shorted wire.
Thanks in advance. I'm lost.
Jim
Jim
