Has anyone had problems with this module? My fuel pump began transfering into the oil at a tremendous rate today. Upon removal from engine it is obvious that the front seal is the reason. My next question was what caused the internal pump pressure to be this great suddenly? I was wondering if the KSB valve didn't do its job therefore pressure rose dramatically. I turned the key to run position and checked for power to the KSB and discovered none. Ambient temp. was high enough that there should have been. Seems to me that the control module is not energizing the KSB when it should. I was wondering how troublesome these modules are. The thermister seems to test out OK. All other functions of the control module appear to be operating properly. Thanks in advance.
