Nice friend of mine came over with his mid 90's 4. 3 Blazer. The battery was getting drained overnight.
I unhooked the ground and put a multi meter in between the ground on the battery and the ground cable. It was showing a 12. 6 volt draw. I went to the altenator, unhooked it and the draw went away. This means the altenator is bad, correct.
While running the battery was in the 13. 5-14. 5 volt range, and the altenator was putting out 14. 5 volts. If you let it run long enough, it would just give up and die.
Do you think I told him right about the alt being bad?
Always ready to help!
2000 2500 Red Sport quad cab, 4x4, K&N, DDI's, straight piped, boost, pyro and fuel pressure gages, Hot Power Edge, mean looking set of 33. 5" tires, Snap On diamond tool box, Marine Corps window sticker, Semper Fi!
1972 340 Cuda'. Original tripple Black, 340 car w/air. Good clean car, super stock springs, Weld Prostars, shaker hood, strong 340 with a 727/4000 stahl, 4. 56... . Bombs away!
NRA Life Member. http://www.geocities.com/chadsheets
