electronic speedo
Brakes, vacuum booster vs. hydroboost system?
Alternator resolution. permanent easy fix
I need help with trying to make a Dodge Getrag 5 speed work with a 1994 gm speedo. I know the speedo needs something with 40 tooth relucutor ring but I am not sure a scew on adatpter style will work. Has anyone done this yet? Thanks for any help. pmartinez.
Ive never done one on a getrag but have on large trucks before
If you install your generator on the transmission or t-case from the gm it should read it , then you might need to get one of those adapter boxes to spped it up or slow it down
Call Isspro or a good guage shop can fix you up
