NO.
Vgt is expensive to build, requires a lot of computer, etc. It is also not very reliable over time because those moving parts are in a very hostile environment--exhaust system, and the hot part of it, with soot, etc. Cummins mentioned this at the intro as reasons not to use variable geometry. The new HY35 has a slightly larger compressor side, oiling puddles under the bearings, and electronic control of the pneumatic wastegate pressure pot. The flange is a little thicker for better gasket durability. That is it for the turbo.
