I have been posting to a lot of threads lately that deal with fuel system parts and I thought I'd post some interesting findings.
Recently I tore down my truck to do some BOMBing. While apart I started checking on banjo bolts and such. . trying to ensure I would not have fuel supply problems in the near future.
One of the calls was to HVAC. He pointed me to Aeroquip fittings. . called a 'Weber' adapter. its a 12mmx1. 5mm hollow fitting w/a #6 AN on the other end. It takes 5 to totally eliminate the Banjo's. You will also need 4- 90* #6 AN fittings and a 45* fitting.
To date I have only replaced the fittings between the lift pump (in the stock location) and the injection pump. I ordered the stainless hose but decided it was a PITA and used 5/16" black fuel hose.
Before I had:
14-15 at idle
12-13 at cruise
8-11 at WOT
Now I have:
14-15 at idle
13-15 at cruise (usually 14)
never under 11 at WOT!!! (usually 12)
I drove 400mi this weekend and watched it very close. . the electronic gauge that remembers min's and max's really helped too
I don't know if it'll affect the lift pump longevity but taking the load off of the pump has to help a bit. My primary concern was not running out of fuel w/the new injectors I installed.
I will replace the feed lines to the lift pump but I'm waiting until I have time to swap out the tank pickup to a larger hose.
Now I'd like to hear questions and comments... I have yet to decide what the next step and contemplate the reprocussions of the current mods.
Thanks,
Mark
Before I had:
14-15 at idle
12-13 at cruise
8-11 at WOT
Now I have:
14-15 at idle
Thanks,
Mark
